Clears the event counters for the FDB MAC-tracking feature.
mac_addr | Specifies a MAC address, using colon-separated bytes. |
all | Clears the counters for all tracked MAC addresses. |
N/A.
The clear counters command also clears the counters for all tracked MAC addresses.
The following example clears the counters for all entries in the MAC address tracking table:
Switch.1 # clear counters fdb mac-tracking all
This command was first available in ExtremeXOS 12.3.
